Jimny cuts out occasionally
- Chadd
21 Jul 2013 07:54 #77723
by Chadd
Replied by Chadd on topic Jimny cuts out occasionally
Thanks for that,
I'm guessing I can buy this from the stealers without the obligation of them fitting it, or is there a place that forum members use to get parts at discount? I suppose it's only £40 ish.
I Plan on doing this next week when it cools down a bit out there!
22 Jun 2025 15:37 #260967
by Ilic
Replied by Ilic on topic Jimny cuts out occasionally
My 2002 Jimny has this problem of cutting out. The engine warning light and padlock keys indicators come on. Once we’ve safely pulled over and restart the engine it works and drives normally.
Local garage can’t work out what is the fault as no codes come up. The mechanic says that if it is the camshaft/crank shaft sensors it would not restart immediately. We have not needed to ‘cool’ them. Same he says if the fuel filter was blocked as it would not start straight away either.
If anyone has any ideas I would appreciate it.
22 Jun 2025 17:39 #260969
by facade
If it gives up at idle it is more likely the idle speed control valve.
Sometimes they will restart after a few seconds without cooling with water.
I think the padlock comes on when the engine is stopped normally.
Replied by facade on topic Jimny cuts out occasionally
Change the crank sensor anyway, it is usually the crank sensor if it cuts out at speed, and a new one is cheap.My 2002 Jimny has this problem of cutting out. The engine warning light and padlock keys indicators come on. Once we’ve safely pulled over and restart the engine it works and drives normally.
22 Jun 2025 19:04 #260971
by Ilic
Thanks! I will do that
30 Jun 2025 11:06 #261085
by Ilic
Swapped out both the Crankshaft and Camshaft sensors and it did the trick! Thanks for the advice!!
Time to create page: 0.176 seconds
