Damaged steering column and indicator
- Markmcke
01 Jul 2013 17:49 #75682
by Markmcke
Damaged steering column and indicator was created by Markmcke
My 03 jimny O2 was broken into and the steering column/ignition damaged. The indictor stalk was damaged and it looks as if the ignition are and surrounding will need to be replaced. Does anyone have an idea of cost?
01 Jul 2013 18:04 #75686
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Damaged steering column and indicator
If you want it all back on one key you will need all the locks and ecu.
If you can get the code/part no from your ecu (below glove box left hand side) I could check to see if I have one.
Grey pick up Jimny
- Vacneb
01 Jul 2013 18:07 #75688
by Vacneb
Replied by Vacneb on topic Damaged steering column and indicator
If J999 doesnt have the set, give CAM Suzuki a bell - they are quite reasonable on the prices.
Or check vitara-mads thread, he may be able to help you out as he is breaking a Jim at the moment.
- Markmcke
01 Jul 2013 18:40 #75693
by Markmcke
Replied by Markmcke on topic Damaged steering column and indicator
I was looking for a rough price before I start down the insurance route. I've got a £300 excess and don't want to claim if it will only be £350
01 Jul 2013 19:41 #75707
by j999pre
Grey pick up Jimny
If you can fit it yourself your looking at half that max.
Whereabouts are you?
Grey pick up Jimny
- Markmcke
04 Jul 2013 10:44 #76088
by Markmcke
i'm in Glasgow, the car is fine apart from a broken indicator stalk and a damaged passenger lock. it is still starting on the original key etc. i need to get an indicator unit and seen this
www.ebay.co.uk/itm/400379421179?ssPageNa....l2649#ht_4030wt_933
would this be compatible with a jimny o2, i see it has a rear wiper feature but could this still work?
Time to create page: 0.106 seconds
