HELP spring spacers & shock spacers
- coey
08 Jun 2013 17:23 #73179
by coey
HELP spring spacers & shock spacers was created by coey
HI COLULD SOMBODY HELP ? have just fitted the 2inch orange spring spacers and shock spacers but seem to have a bit of a problem! I will give you the size of the spaces from the top of the tyres to the arches
drivers side front 4 1/4 inch
drivers side rear 3 3/4 inch
passenger side front 5 3/4 inch
passenger side rear 5 3/4 inch
any body any ideas what I have done wrong any help would be very greatfull
08 Jun 2013 18:19 #73184
by Halford
Replied by Halford on topic HELP spring spacers & shock spacers
did you swap the front and rear drivers side springs around ?
did you measure before fitting the spacers, was the unevenness already there ?
one of the springs is longer on purpose
The following user(s) said Thank You: coey
- coey
08 Jun 2013 18:53 #73185
by coey
Replied by coey on topic HELP spring spacers & shock spacers
hi Halford
no we did the back first & then the front but even then we did them one at a time ( ie one off one on)
but I did put new rear Monroe shocks on it and It was all the same before we started !!!!
- UKDAN
08 Jun 2013 19:15 - 08 Jun 2013 19:20 #73190
by UKDAN
Replied by UKDAN on topic HELP spring spacers & shock spacers
Try driving it for a few miles give everything a chance to settle, might get a loud dong sound as one of the springs seats itself correctly. Or have a look at the taller one to make sure the end of the spring is butted up against the step in the lower seat & not on top of it.
Last edit: 08 Jun 2013 19:20 by UKDAN.
- UKDAN
08 Jun 2013 19:23 #73196
by UKDAN
Or is it the famous Jimny lean ?
- UKDAN
08 Jun 2013 19:36 #73201
by UKDAN
I fitted the spring spacers to mine last week & it's looks great but just popped outside & measure mine & all are different between 3 1/2" & 4 1/2" but I'm not worried still looks good & drives totally fine.
Time to create page: 0.104 seconds
