Lambda/ oxygen sensor.
  • Fyffe
19 Apr 2013 15:55 #69031 by Fyffe
Lambda/ oxygen sensor. was created by Fyffe
hello all,
Was wondering if any of you guys have come up with or know a simple way for testing the lambda sensor with out using the diagnostics
Cheers Jack
  • markyp2000
19 Apr 2013 16:59 #69034 by markyp2000
Replied by markyp2000 on topic Lambda/ oxygen sensor.
Scope it and see if the voltage changes
22 Apr 2013 11:17 - 22 Apr 2013 11:18 #69225 by Johnniehec
Replied by Johnniehec on topic Lambda/ oxygen sensor.
Little Jimny (soft top, older cam belt engine) failed MOT on emissions, does any one know if the manifold and cat lambda sensors are the same part and if they're the same part for the two engines (cam belt and cam chain) as I could try swapping lambdas with Big Jimny (cam chain) which passed?
I did notice when I got home the earth wire from the bulkhead to the top of the engine was disconnected, would this be likely to affect the lambdas?
MarkyP what do you mean by "scope it"?
Cheers
John.
PS no engine management light on.
Last edit: 22 Apr 2013 11:18 by Johnniehec.
22 Apr 2013 19:46 #69264 by Rhinoman
Replied by Rhinoman on topic Lambda/ oxygen sensor.
The missing earth wire could well effect the reading however its worth putting a new sensor in anyway if it hasn't been changed for a while as they do slow down with age.
'Scope it' means to put an oscilloscope on the signal and check the reaction time.
22 Apr 2013 20:43 #69278 by Johnniehec
£175 from the Stealer, or cheapie off Fleabay?
Any other options?
Cheers,
John.
  • markyp2000
22 Apr 2013 20:54 #69280 by markyp2000
No jimny should fail the cat test/emissions test reason being there is no limit guidence in the mot testers emissions data book tell then to check in the book and it then has a standerd co test so the co no more than 3.5% hc no more than 2000 ppm and the lambda doent get tested
For some reson a lot of soft tops fail cat tests hut the hard tops pass
Trust me on this i know as im a mot tester
Hope this helps
Time to create page: 0.169 seconds
