rear disc conversion
  • deedar
07 Apr 2013 08:51 #68076 by deedar
rear disc conversion was created by deedar
hi just woundering how hard it will be to convert the the brakes to discs and what i will need for it any help will be great thanks
  • markyp2000
07 Apr 2013 09:07 - 07 Apr 2013 09:08 #68077 by markyp2000
Last edit: 07 Apr 2013 09:08 by markyp2000.
  • gus2000
07 Apr 2013 20:34 #68138 by gus2000
Replied by gus2000 on topic rear disc conversion
Hello, It´s interesting to analyze the installation of rear discs together with full floating axle conversion
www.zanfi.it/modules.php?name=catalog&fi...121&products_id=1061
Provides greater security at axle breaks. And prevents that the high clearance of rear bearing distancing the brake pads of the brake disc while driving increasing the brake pedal travel.
  • markyp2000
07 Apr 2013 21:48 #68146 by markyp2000
Replied by markyp2000 on topic rear disc conversion
So how does the hand brake work?
08 Apr 2013 09:02 #68167 by facade
Replied by facade on topic rear disc conversion
Probably a transfer brake like on the 410
  • bigoffroader
08 Apr 2013 09:22 #68169 by bigoffroader
Replied by bigoffroader on topic rear disc conversion
markyp2000 wrote: So how does the hand brake work?
The rover brake calipers that the kit is designed for have the handbrake mechanisum built into them, so you use the existing jimny handbrake cable and use the adapters in the kit to attach it. I've made my own version of this idea but used the calipers off the 2.5 v6 model and it works a treat, no more brake fade and failing handbrake after a hard day offroading in mud and water.
Time to create page: 0.103 seconds
