alloy troubles
  • puddletruck
04 Apr 2013 16:32 #67827 by puddletruck
alloy troubles was created by puddletruck
Hi everyone.Got my jimny a few weeks ago and joined bigjimny for interest and help.I learnt that Daihatsu alloys would fit my jimny and purchased some.Now the trouble is the studs on my jimny are approximately 2" long which was fine for steel wheels but the alloys are 2" thick.This obviously means that I carnt get the nuts on.Also the alloys have a flat face where studs go and not angled AND the studs are 12mm thread and the alloy diameter must be 16mm.
So can anyone give me advice to what I can do to get them to fit or shall I just sell them.
  • markyp2000
04 Apr 2013 16:52 #67829 by markyp2000
Replied by markyp2000 on topic alloy troubles
Post a pic of what you mean
04 Apr 2013 16:58 #67830 by facade
Replied by facade on topic alloy troubles
Easiest to sell them. (but I'm getting old and really can't be bothered faffing about ;) )
You can get some nuts if you search around- mrtee.co.uk likely has them, if not, you can get some made up, but you won't get much change from £40 a set, which makes cheap wheels quite expensive.
04 Apr 2013 17:12 #67834 by facade
Actually you need to check the diameter of the locating hole against the hub on the jimny, if it isn't the same, you need hub rings too.
Alloys with flat holes locate on the central hub ring (they usually seize onto the hub quite nicely too) Then you need a shouldered nut with a flat washer- mrtee calls them a sleeve nut. Without the correct hub ring the wheels will run ouut of centre.
  • puddletruck
04 Apr 2013 18:18 #67843 by puddletruck
Replied by puddletruck on topic alloy troubles
Thanks for your replys.I think I will try mrtees first and see if he can help.
Time to create page: 0.304 seconds
