Engine fault light - which code reader do I need?
- discotroll
30 Mar 2013 12:34 #67321
by discotroll
Engine fault light - which code reader do I need? was created by discotroll
Well..
The good news is that after wrecking a piston in my 02 Jimny I stripped it all down, replaced the piston and put it back together (IN MY DRIVEWAY, IN THE SNOW :evil: ) and it's all working fine.
Bad news is that 3rd trip out and the engine management light has come on permanently.
I'll have a good shuffle around under the bonnet to make sure everything is attached okay but engine is running as smooth as I could ask for from the little unit and no-one on the forum seem overly concerned when this happens - question is (yes - I'll get there eventually) is what kind of reader do I need from ebay to read the code - is it a universal one thar reads 'CAN, KWP 2000, ISO 9141-2, PWM, VPW'? Worth the investment anyway but don't want to buy the wrong one!
Thanks,
DT.
Thanks,
DT.
30 Mar 2013 12:59 #67323
by facade
Replied by facade on topic Engine fault light - which code reader do I need?
IRRR, you have the single cam engine, so you need the Rhinoman one, that is now available from the shop here.
- discotroll
30 Mar 2013 13:06 #67325
by discotroll
Replied by discotroll on topic Engine fault light - which code reader do I need?
Excellent - will go and check my connector details as suggested then get one ordered-up!
Thanks!
Thanks!
- discotroll
30 Mar 2013 13:41 #67328
by discotroll
By the way - I *have* ended-up with a 'spare' connector block that doesn't seem to connect to anything!! :whistle:
It's light grey, 3-pin female and exits the wiring loom just behind the alternator. It's only on about 10cm of wire and I can't see anywhere that it could connect to - am I right to assume this is unused on the soft-top Jim?
Time to create page: 0.302 seconds
