Sammy guts in a jimny case
  • Dave cc
23 Mar 2013 20:21 #66692 by Dave cc
Sammy guts in a jimny case was created by Dave cc
Never tried it but does anyone know if you can put sammy axle guts into a jimny case or is it easier just to weld some new brackets onto the Sammy cases ?
  • MWells
23 Mar 2013 20:31 #66694 by MWells
Replied by MWells on topic Sammy guts in a jimny case
I believe the sammy axles are narrower than jimny axles although i could be wrong.
  • Dave cc
23 Mar 2013 20:46 #66699 by Dave cc
Replied by Dave cc on topic Sammy guts in a jimny case
MWells wrote: I believe the sammy axles are narrower than jimny axles although i could be wrong.
Possibly i know Sammys were 2 inches wider than Sj i know lots of jimny axles break also i never broke any of my Sj axles so just wondered if they are better cant be that much diffrence will prob be able to make it fit :)
  • Smoggy
23 Mar 2013 20:50 #66700 by Smoggy
Replied by Smoggy on topic Sammy guts in a jimny case
I have Sammy axles into a Sammy case with a jimny rear diff housing drilled, tapped and bolted onto the Sammy axle diff half ( if that makes sense ). Inside is a Jimny ARB locker with Sammy side gears to suit the axles which are chromo 4340 items.
  • Smoggy
23 Mar 2013 20:52 #66701 by Smoggy
ps As you probably know Dave I am also running 285/75 x 16s. I have given them quite a bit of stick so far.
  • TomDK
23 Mar 2013 22:00 #66713 by TomDK
Replied by TomDK on topic Sammy guts in a jimny case
Samurai axles are around 50 mm narrower than Jimny axles.
Time to create page: 0.148 seconds
