changing rear brake shoes?
- chrisharman
22 Mar 2013 20:39 #66587
by chrisharman
changing rear brake shoes? was created by chrisharman
Any one got any tips on changing rears shoes on a 2000 reg jim?
- GuardianAngel
22 Mar 2013 21:03 #66592
by GuardianAngel
Replied by GuardianAngel on topic Re: changing rear brake shoes?
Takes photos before you disassemble. Get some brake cleaner and degrease the adjusters, then regrease the sliders. Try and remember how far the adjuster screw is wound in to prevent the need to spend ages fiddling with the adjusters.
Put a dab of copper ease on the back plate where the shoes make contact to prevent sticking.
Finally, be prepared to swear and have no skin left on your hands when putting it all back together :woohoo:
- chrisharman
22 Mar 2013 21:12 #66593
by chrisharman
Replied by chrisharman on topic changing rear brake shoes?
The trouble im havings is the hand brake arm seems to be getting jammed on the adjuster.
Ive got the shoes and springs into place
23 Mar 2013 09:59 - 23 Mar 2013 09:59 #66624
Replied by mlines on topic changing rear brake shoes?
Sounds like the adjuster is the wrong way around?
The fork at the end of the adjuster has different lengths on each side of the fork and you have to get it the right way around
www.bigjimny.com/images/documents/Changi...Rear_Brake_Shoes.pdf
Last edit: 23 Mar 2013 09:59 by mlines.
- markyp2000
23 Mar 2013 11:09 #66629
by markyp2000
Replied by markyp2000 on topic changing rear brake shoes?
Sounds like you need a proper machanic to do it if your not competant at doing a job aspecialy brakes wich is a major thing on a car why bother and risk getting it wrong crashing the car and may end up killing yourself or some one else i know people are trying to save money but it will end up costing more
- RichiesJimny
23 Mar 2013 12:40 #66635
by RichiesJimny
Well said Mark
Replied by RichiesJimny on topic changing rear brake shoes?
markyp2000 wrote: Sounds like you need a proper machanic to do it if your not competant at doing a job aspecialy brakes wich is a major thing on a car why bother and risk getting it wrong crashing the car and may end up killing yourself or some one else i know people are trying to save money but it will end up costing more
Well said Mark
