I think I've fu*#%d my Jimny :(
- hjb_1990
16 Mar 2013 15:46 #65913
by hjb_1990
I think I've fu*#%d my Jimny :( was created by hjb_1990
Not very happy with myself today. I think I've ruined my Jimny. Basically I haven't had it long and when I first got it obviously did all the engine checks and have done once a month through the winter. However the other day the engine management light came on and my heating in the jimny stopped working which I though odd. Took a look under the bonnet and the coolant tank was empty! I dunno how it ha emptied so quick! Anyway I cleaned all the bottle out and topped it up along with filling the rad up with coolant.
I ran my jeep for 20 min to warm up and pump it through a bit. The temp gauge goes up nice and quick and sits in the middle where it should. I can feel obvious heat from the engine with bonnet up but still no heat through vents inside. I checked the oil and doesn't seem to be any browny liquid to suggest hea damage but there was quite a bit of gunk in the coolant bottle and small amounts in the rad. The engine is running sweet and idles well and drives as good as ever so no obvious damage yet!?
Any suggestions on whether I've buggered it and/or how to sort the heating? Should I do a full flush/change of both coolant and oil ASAP?
- reaper
16 Mar 2013 15:50 #65914
by reaper
Replied by reaper on topic I think I've fu*#%d my Jimny :(
Have you checked for leaks in the cooling system as they dont normally lose much if any coolant, if all checks out ok you may have an airlock or sticky thermo
- BigMat
16 Mar 2013 16:23 #65919
by BigMat
Replied by BigMat on topic I think I've fu*#%d my Jimny :(
Sounds exactly the same as when my head gasket went
- markyp2000
16 Mar 2013 16:29 #65920
by markyp2000
Replied by markyp2000 on topic I think I've fu*#%d my Jimny :(
Like its been said check the thermostate top hose engine end 2 12mm bolts make shore you refit it the right way up
The rad cap may be a fault
The fan may not be cuting in fully when hot
If all the above fail book it in a garage and have a sniffer test done on the coolent for exhaust gasses and a pressure test on the coolent system
- hjb_1990
16 Mar 2013 18:49 #65957
by hjb_1990
Replied by hjb_1990 on topic I think I've fu*#%d my Jimny :(
Dont suppose anyone could give me a brief description on how to check the thermostat hosing as i have never worked on thermostats before.
Ta
Ta
- markyp2000
16 Mar 2013 19:00 #65960
by markyp2000
Remove the state the should be a temp stamped on it around 82º boil a pan of water tie some string to the stat and put it in if it opens then its fine
hjb_1990 wrote: Dont suppose anyone could give me a brief description on how to check the thermostat hosing as i have never worked on thermostats before.
Ta
Time to create page: 0.166 seconds
