Transfer whine...... Help required....
  • Jimny - aus
15 Mar 2013 13:42 #65758 by Jimny - aus
Transfer whine...... Help required.... was created by Jimny - aus
I recently bought a 2009 jimny, stock as a rock, bought and fitted a 80mm lift, 3" extended brake lines and 215,75,15 muddies, after going for a few light 4x4 days I noticed the transfer had a horrible whine and it was fairly constant from about 40kmh and got louder under brakeing . After stripping the transfer and finding a cracked sincro - at the end if the main drive shaft - and replacing it went. The noise went away for about 2 months and since 4x4ing again the dreaded whine is back. Not to mention the 4x4 has been abit inconsistent to select since buying it. I'm stumped on what to look for, should I replace it or is it something common amongst jimny's.
Any help would be appreciated.
Cheers
  • panosd
15 Mar 2013 13:54 #65763 by panosd
Replied by panosd on topic Transfer whine...... Help required....
Check the bearings fo the t-case and the t-case mounts.
It should be one of the above your problems.
  • Jimny - aus
15 Mar 2013 13:57 #65766 by Jimny - aus
Replied by Jimny - aus on topic Transfer whine...... Help required....
Yea the bearings are all good it's had 2 batches of fresh oil since e rebuild and on the last lot noticed it had a lot of grey..... And my d/s mount has been previously welded together :S
  • reaper
15 Mar 2013 15:19 #65776 by reaper
Replied by reaper on topic Transfer whine...... Help required....
If doing alot of offroading may be worth looking at an upgrade , rocklobster box is the best upgrade i have on my truck
  • Paul4x4
15 Mar 2013 15:32 #65777 by Paul4x4
Replied by Paul4x4 on topic Transfer whine...... Help required....
reaper wrote: If doing alot of offroading may be worth looking at an upgrade , rocklobster box is the best upgrade i have on my truck
Yeah, that would be the best bet.
After the swap you don't need to be worried about the t-box whining no more, because it comes as a standard feature with those! :laugh:
  • Jimny - aus
15 Mar 2013 15:46 #65779 by Jimny - aus
:laugh: :laugh: :laugh: I'm hoping to get a replacement box and build one with a reduction gear set.... I think manual hubs are a must I'm sick of my transfer trying to eat itself all the time... Plus I do a lot of highway K's so something quite would be great....
