4WD High and Low
  • cool-wool
14 Mar 2013 13:04 #65644 by cool-wool
4WD High and Low was created by cool-wool
Hi, I've just become the owner of a 2008 Jimny and am a bit in a pickle with the 4WD.
I seem to get into 4WD-H without problems pushing the 4WD button and getting the green light on the dash. The problem I'm having is with the LOW gears. When I push the 4WD-L button I get a beeping sound and a flashing 4L indicate on the dash which then goes out. Car does not enter LOW range though.
I know that the low range gears work because, for some strange reason, the other day I collected the car from a car wash and both the green 4WD and orange 4L lights were on and the LOW gears WHERE engaged (noticable in driving).
I even had trouble disengaging the 4WD !! In fact pressing either 4WD button only resulted in beeping sounds.
Eventually got back to 2WD (I think) doing some reversing.
Any ideas ?
thanks
  • GuardianAngel
14 Mar 2013 13:24 #65645 by GuardianAngel
Replied by GuardianAngel on topic Re: 4WD High and Low
Dodgy wiring to the transfer box maybe? Get underneath and have a look to see if there are any broken wires etc.
14 Mar 2013 13:27 - 14 Mar 2013 13:45 #65646 by gilburton
Replied by gilburton on topic 4WD High and Low
4WDL can only be selected after 4WDH is engaged. High can be selected on the move at low speeds.
You must use the clutch(try fully down) and be at a standstill to select low. Hope that helps?? :)
Sounds like someone at the car wash has been playing?? Proves it works though lol
Apologies if you know this already but do not drive in 4WD on wet or dry tarmac. Only slippery surfaces!
I started off high and worked my way down ever since :-)
Last edit: 14 Mar 2013 13:45 by gilburton.
The following user(s) said Thank You: cool-wool
  • cool-wool
14 Mar 2013 16:09 #65660 by cool-wool
Replied by cool-wool on topic Re: 4WD High and Low
Thanks for rapid suggestion.
Got solution from gilburton :)
  • cool-wool
14 Mar 2013 16:13 #65662 by cool-wool
Replied by cool-wool on topic 4WD High and Low
gilburton wrote: 4WDL can only be selected after 4WDH is engaged. High can be selected on the move at low speeds.
I wasn't flooring the clutch enough !! :blush: Got the hang of it now and everthing works OK.
Thanks for your help and tip on wet tarmac.
  • JivingDaddy
14 Mar 2013 16:43 #65663 by JivingDaddy
Replied by JivingDaddy on topic 4WD High and Low
I don't have a 4L light on my dashboard, only a 4WD.
Maybe cos it's an 05 O2 with the manual lever.
Or, has a bulb gone? No mention of a 4L light in the Owners book tho'.
Time to create page: 0.168 seconds
