15"x10" wideboy wheels - What size tyres would fit
  • Chris the Phys
10 Mar 2013 15:36 #65159 by Chris the Phys
What tyres would fit on these wheels with a 2in or 3in suspension lift or r they no good for a jim?
  • Dave cc
10 Mar 2013 16:29 #65171 by Dave cc
think they will be far to wide with a mad offset 7J or 8J i beleive would be ok as i think that is what is on my Blue jim with 31x10.50 15s it has a 2inch lift but rubs badley so going o do a 2 inch body lift to help think that will sort it
  • Paul4x4
10 Mar 2013 17:29 #65182 by Paul4x4
If you're planning on driving offroad, then the tires should be at least 2" wider than the wheels, so there isn't much options to choose from with that wide wheels, unless you go for 33s...
  • Chris the Phys
10 Mar 2013 19:09 #65208 by Chris the Phys
Replied by Chris the Phys on topic 15"x10" wideboy wheels - What size tyres would fit
Dave cc wrote: think they will be far to wide with a mad offset 7J or 8J i beleive would be ok as i think that is what is on my Blue jim with 31x10.50 15s it has a 2inch lift but rubs badley so going o do a 2 inch body lift to help think that will sort it
Cheers
Not sure I under stand about offset and 7/8J
Thanks anyway :)
  • Chris the Phys
10 Mar 2013 19:11 #65209 by Chris the Phys
Paul4x4 wrote: If you're planning on driving offroad, then the tires should be at least 2" wider than the wheels, so there isn't much options to choose from with that wide wheels, unless you go for 33s...
Cheers
  • little jimny
10 Mar 2013 20:32 #65222 by little jimny
Replied by little jimny on topic 15"x10" wideboy wheels - What size tyres would fit
Cheers
Thanks anyway :)
offset is all about how far they sit in or out of the arches, and 7J or 8J is the rim width in inches
Time to create page: 0.200 seconds
