inner drivers wing
- 03troakey
28 Feb 2013 18:22 #64209
by 03troakey
inner drivers wing was created by 03troakey
can i get ride of the air tank ting under driver wing
- markyp2000
28 Feb 2013 18:28 #64212
by markyp2000
Replied by markyp2000 on topic inner drivers wing
You can if your fitting a snorkal
- 03troakey
28 Feb 2013 18:52 #64214
by 03troakey
Replied by 03troakey on topic inner drivers wing
the one for hubs
28 Feb 2013 19:22 #64217
by facade
Replied by facade on topic inner drivers wing
Yes if you are have fitted manual hubs. It keeps enough vacuum to snap the hubs from one side to the other, I wouldn't like to guarantee operation of the vacuum hubs without it though.
- 03troakey
02 Mar 2013 11:57 #64349
by 03troakey
i got manuel hubs any way
02 Mar 2013 12:30 #64350
by facade
Then you can remove all the air solenoids and pipework from under the battery, join the vacuum switch wires together so the 4wd light works, remove the airtank and cap the vacuum port at the inlet manifold.
Put everything in the same box as the vacuum hubs in case you sell the car to someone who expects it to have the original parts.
