Modular or Alloy Wheels
- rogerdadodger
24 Feb 2013 09:11 - 24 Feb 2013 09:53 #63810
by rogerdadodger
Modular or Alloy Wheels was created by rogerdadodger
I've noticed a lot of the bigger trucks on here have the modular steel wheels with the big tyres! Is this just because of the extra strength of steel or something else? I've got a set of the three spoke Suzuki alloy wheels & a set of the Oz alloy wheels, could I fit a set of the 30 or 31 inch tyres or won't they fit right?? Has anyone got a picture of the Oz wheels with the big tyres fitted??
Cheers
Cheers
Last edit: 24 Feb 2013 09:53 by rogerdadodger.
24 Feb 2013 11:11 #63821
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Modular or Alloy Wheels
The modular have a better offset so you don't need spacers. Also they are wider and I'd say stronger. You could fit big tyres to the alloys though. I'm sure someone will have pics.
Grey pick up Jimny
- GuardianAngel
24 Feb 2013 14:14 #63835
by GuardianAngel
With that in mind, which are harder on wheel bearings; spacers or modulars. With my logic I would say modulars...
Replied by GuardianAngel on topic Re: Modular or Alloy Wheels
j999pre wrote: The modular have a better offset so you don't need spacers. Also they are wider and I'd say stronger. You could fit big tyres to the alloys though. I'm sure someone will have pics.
- adamjimny
25 Feb 2013 02:44 #63904
by adamjimny
Replied by adamjimny on topic Re: Modular or Alloy Wheels
Bigger the offset the worse on bearings they are so if the wheel with spacers stick out more they are worse and vice versa
Sent from my GT-I9300 using Tapatalk 2
- iloveics
25 Feb 2013 22:49 #63980
by iloveics
I would say spacers are worse, purely because they all seem to be +32mm, where as most offset wheels i've seen (and emailed the sellers about) are +20mm
Replied by iloveics on topic Re: Modular or Alloy Wheels
Time to create page: 0.160 seconds
