Pulling to the right after fitting 3" lift
- GWR
- Visitor
23 Feb 2013 20:24 #63760
by GWR
Pulling to the right after fitting 3" lift was created by GWR
Hi guys. I though I would pick your brains. I have an 04 Jimny and have just fitted a pro comp 3" lift with the adjustable panhard rod rods, steering damper and caster correction bushes. Now my question is why is it now pulling to the right? Could it be the axel alignment? Or maybe my tracking? Any ideas?
- markyp2000
- Visitor
23 Feb 2013 20:36 #63761
by markyp2000
Replied by markyp2000 on topic Pulling to the right after fitting 3" lift
Could be both check your axel is align center then check your track rod ends make shore he bushes are in correct and get the tacking checked
- supergaz
- Visitor
23 Feb 2013 21:06 #63769
by supergaz
Replied by supergaz on topic Pulling to the right after fitting 3" lift
You need to adjust your steering arm due to the extra drop. This is the distance from the pitman arm to the nearside hub.lift makes no difference to the tracking.
- Dave cc
- Visitor
23 Feb 2013 21:42 #63781
by Dave cc
Replied by Dave cc on topic Pulling to the right after fitting 3" lift
agreeded just needs a tweak on the drag link to compensate for the lift
- GWR
- Visitor
24 Feb 2013 17:52 #63870
by GWR
Replied by GWR on topic Pulling to the right after fitting 3" lift
Thanks guys I will take a look when it stops snowing
- GWR
- Visitor
25 Feb 2013 20:21 #63955
by GWR
I checked and adjusted the panhard rods again then adjusted the steering arm and now my steering wheel is straight and the steering is much better, only a very slight pull to the right
Time to create page: 0.986 seconds
