Grinding noise after 4wd used
- highpeaksphil
23 Feb 2013 10:13 #63704
by highpeaksphil
Grinding noise after 4wd used was created by highpeaksphil
Hi i'm new to ths forum and Jimnys.
Brought one for the wife last oct, its an 01 plate with 88k on the clock. as its only a road car at moment (she won't let me take it off road yet) it wasn't until the snow arrived that 4wd was used and then only briefly. After using 4wd to getout of works car park and putting back into 2wd there was an awful grinding noise coming from the car. It sounded like the front diff was about to explode orrip itself to bits. Its gone now but just rather wary of using 4wd again, just in case it comes back
- markyp2000
23 Feb 2013 10:33 #63709
by markyp2000
Replied by markyp2000 on topic Grinding noise after 4wd used
Sounds like one of the front hubs isnt disengaging all the way of the transfer box isnt fully disengaged
- highpeaksphil
23 Feb 2013 11:43 #63714
by highpeaksphil
Replied by highpeaksphil on topic Grinding noise after 4wd used
many thanks for those 2 .... where do i go now, my mechanicing skills used to be rather good .. just not tried them in few yrs! which problem shall i address first? or check first
- reaper
23 Feb 2013 11:56 #63715
by reaper
Replied by reaper on topic Grinding noise after 4wd used
Gear stick is easy to check
Just cycle it through a few times 2wd 4h 4l
Then the hubs jack a corner and spin the wheel , then put in 4wd and spin again
This will tell you if hubs are stuck
23 Feb 2013 13:59 #63725
by facade
Replied by facade on topic Grinding noise after 4wd used
The hubs will only engage/disengage with the ignition on, and some vacuum in the tank, so usually the engine has to be running due to leaks.
So if you follow Reapers suggestion, do the 4wd 2wd 4wd 2wd lever stuff engine off, and then jack up to see if the hubs were stuck.
Standing with the engine ticking over, wind down a window and you should hear Clickclick when you engage 4wd, and the green light should come on straight away steady, then clackclack if you move back to 2wd, this means the hubs are likely working.
clickclick & clackclack happen as fast as you can say it, if you get click...2...3...click there is a vacuum leak.
There is loads of info on the system, and several threads on here, but the hubs rely on perfect wheel bearings to operate, if the wheel bearing has gone, there will be a leak, and the hub wont disengage, (it won't need to engage either, as it is always engaged)
- markyp2000
23 Feb 2013 14:09 #63728
by markyp2000
But facade if the hub was stuck on due to the pipe being split and the hub not being released then puting the leaver in 4wd L or H with the engine of and jacked up then it would still be in 4wd
Plus if you put your jimny in 4wd anr swich the engine of then it would still be in 4wd as there is no vacuum to pull them off
