Bonnet washer jets
- jimnyonhigh
14 Feb 2013 17:56 - 14 Feb 2013 17:57 #62549
by jimnyonhigh
Bonnet washer jets was created by jimnyonhigh
Today i noticed washer fluid bubbling around one of the washer jets, does anybody know a fix or how to take them apart ?
I seen a few universal jets for sale, could anybody recomend any good ones.
Thank you
Thank you
Last edit: 14 Feb 2013 17:57 by jimnyonhigh. Reason: mistakes
- horam_jimny
14 Feb 2013 18:40 #62555
by horam_jimny
Replied by horam_jimny on topic Bonnet washer jets
Do you mean its bubbling when you're using it as in it seems blocked? Can't speak for the Jimny as mine work ok but with other cars I've just taken the nozzle off and either blown back through the hole or held it on the pipe so the water would go through the jet the wrong way and use the pressure to blow out and blockage. Hope that made sense as I couldn't really work out how to say it!
- jimnyonhigh
14 Feb 2013 18:46 #62559
by jimnyonhigh
Replied by jimnyonhigh on topic Bonnet washer jets
Hi thank you for the reply, yeah it does it after a few squirts and starts to bubble up around the jet, the other one is fine.
It is not a mssive issue but i was just curious, regarding the jets themselfs are thay easy to take apart ? i could not see a nut or anything to loosen the jet itself and did not want to brake it.
- horam_jimny
14 Feb 2013 18:54 #62563
by horam_jimny
Sounds like there is a tiny piece of crud stuck in the pipe that moves up with the flow to then block the jet hence why you get a short squirt before it starts to bubble. On my other cars the pipe just pulls off from the inside and the washer then clips to the bonnet. You should be able to remove it without any tools unless Suzuki have done something radical just to make our lives difficult. If I remember tomorrow I will have a look to check on mine.
- horam_jimny
15 Feb 2013 17:47 #62684
by horam_jimny
Checked under the bonnet this afternoon and it won't require any tools just pop the pipe off by hand then the jet pops off with two clips. Run the washer without the jet to clean through the pipe then try and run water back through the jet the wrong way to flush any debris out the jet itself. Should sort it in a few minutes.
- JerseyJimny
16 Feb 2013 08:21 #62742
by JerseyJimny
Replied by JerseyJimny on topic Re: Bonnet washer jets
If all that fails I am planning on running a hose from the washer jet and attaching it to the wiper so your wipers don't get full of mud!
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk 2
