How do brake pads return to their rest position?
- GuardianAngel
- Visitor
10 Feb 2013 22:39 #62069
by GuardianAngel
How do brake pads return to their rest position? was created by GuardianAngel
OK this might be a dumb question, but...
I fitted a new set of disks and pads today (only one side so far, as its was freezing and chucking it down
), and I was surprised that there didn't seem to be an obvious mechanism that returns the brake pads to a resting position away from the disk once the piston has retracted (i.e. when you take your foot off the brake peddle).
The pads, as you all probably know, clip into the carrier using spring clips. It's obvious that the piston squeezes them together, but not the reverse.
Am I missing something? How does this work?
- vitara_mad
- Visitor
10 Feb 2013 22:53 #62078
by vitara_mad
Replied by vitara_mad on topic How do brake pads return to their rest position?
its just the presure released off the piston then the pads dont have any presure on them
- mudman
- Visitor
10 Feb 2013 22:56 #62079
by mudman
Replied by mudman on topic How do brake pads return to their rest position?
have a look at the link below it might help it helped me when i was a collage
auto.howstuffworks.com/auto-parts/brakes/brake-types/brake.htm
- GuardianAngel
- Visitor
10 Feb 2013 23:03 #62080
by GuardianAngel
OK, so it really is that simple
Replied by GuardianAngel on topic Re: How do brake pads return to their rest position?
vitara_mad wrote: its just the presure released off the piston then the pads dont have any presure on them
11 Feb 2013 19:06 #62163
by facade
Replied by facade on topic How do brake pads return to their rest position?
The piston seals are square section.
When the brake is applied they stretch and twist slightly as the piston comes out.
Without the pedal pressure the seals relax and pull the pistons back a tiny fraction, allowing the pads to rattle off the disc as it wobbles slightly.
The following user(s) said Thank You: GuardianAngel
- Chriscov1988
- Visitor
11 Feb 2013 19:15 #62165
by Chriscov1988
Replied by Chriscov1988 on topic How do brake pads return to their rest position?
Are fitting new discs and pads relatively easy to do or not? I'm going to give them a go in the week if I get a dry evening.
Time to create page: 0.178 seconds
