Disconnected battery - now 02 wont start...
09 Feb 2013 20:04 #61759
Replied by mlines on topic Disconnected battery - now 02 wont start...
What is the immobiliser warning light doing when you turn it over?
- adamjimny
- Visitor
09 Feb 2013 20:24 #61767
by adamjimny
Replied by adamjimny on topic Disconnected battery - now 02 wont start...
not to sound stupid but have you re-connected the coil packs at the back of the engine? also check you can here the fuel pump prime when ignition is turned on. if not either pump relay has gone or the part of the ecu controlling it. you can connect it to bypass it though
- L7kvv
- Visitor
09 Feb 2013 20:32 #61773
by L7kvv
Replied by L7kvv on topic Disconnected battery - now 02 wont start...
As per another thread on here could the engine be flooded after only running a few seconds. Mine didnt catch this mornining, amd on the scond turn it just wound and wound. Took ages to get it to start
- jimny5
- Visitor
10 Feb 2013 08:16 #61856
by jimny5
Replied by jimny5 on topic Disconnected battery - now 02 wont start...
Sounds like it could be bore washed. If its just turning over and over.
Try some oil down the spark plug holes. Will make it smoke abit, but worth ago.
Time to create page: 0.203 seconds
