brake pads and shoes
  • Skinhead
  • Visitor
  • Visitor
23 Jan 2013 21:56 #59357 by Skinhead
brake pads and shoes was created by Skinhead
Firstly what are good makes of pads and shoes?
I can change front pads no problem but id like to do the rear aswel, is it an easy job? Has anyone got a link an some photos to help me?
Cheers
24 Jan 2013 22:00 #59459 by dirtydogz
Replied by dirtydogz on topic brake pads and shoes
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
25 Jan 2013 18:43 - 25 Jan 2013 18:47 #59549 by mcjimny
Replied by mcjimny on topic brake pads and shoes
Personally as i was offroading and the trucks quite light anyway i just put the cheapest pads in - usually Apec from my local factors. I never had any trouble from them, lasted as long as any pads ive used.
I use mole grips to get the spring back on, levering it against the hub. Its the hardest part of the job, keeping it all together and pulling the spring across. I had a few rapped knuckles..... :pinch:
Last edit: 25 Jan 2013 18:47 by mcjimny.
  • Skinhead
  • Visitor
  • Visitor
25 Jan 2013 21:41 #59579 by Skinhead
Replied by Skinhead on topic brake pads and shoes
mcjimny wrote: Personally as i was offroading and the trucks quite light anyway i just put the cheapest pads in - usually Apec from my local factors. I never had any trouble from them, lasted as long as any pads ive used.
Someone else said the same earlier about the molegrips and yes i think im going to go for the apec pads, cheers bud.
25 Jan 2013 22:19 #59588 by mcjimny
Another tip: Take a few close up pictures of it or do a side at a time, common sense but i removed both shafts to do the bearings and replaced shoes too, i took pictures beforehand and i was glad i did as i put the adjuster the wrong way round so had no hand brake still. :blush:
  • Skinhead
  • Visitor
  • Visitor
25 Jan 2013 23:05 #59603 by Skinhead
mcjimny wrote: Another tip: Take a few close up pictures of it or do a side at a time, common sense but i removed both shafts to do the bearings and replaced shoes too, i took pictures beforehand and i was glad i did as i put the adjuster the wrong way round so had no hand brake still. :blush:
Will do that, hoping someone post a video for me :)
Time to create page: 0.359 seconds
