Whir at 1000rpm
- jbs215
- Visitor
07 Jan 2013 19:44 #57413
by jbs215
Whir at 1000rpm was created by jbs215
Hopefully somebody can help.
I have a 2000 jimny with G13bb engine.
Once it has warmed up the idle drop to around a steady 800rpm ish.
If held at 1000rpm you get a little whir from the engine.
Only appears at 1000rpm and goes away at idle.
Only noticed it as if revved the it first stops at 1000rpm for a few seconds then drop to 800rpm.
I have removed the Power Steering belt and the fan/alternator belt and ran for a few seconds but it still remains so it rules out any ancillary so definitely an engine noise.
Also changed the oil and filter but no change.
Can anybody shed some light
Thanks James
Thanks James
- reaper
- Visitor
07 Jan 2013 20:01 #57416
by reaper
Replied by reaper on topic Whir at 1000rpm
Is your truck modified ?
Always helps to give as much info as you can
To be honest you will stand a much better chance of figuring out the problem than we will guessing what it could be
Wheel bearing or tyres would be my guess
- jbs215
- Visitor
07 Jan 2013 20:22 #57423
by jbs215
Replied by jbs215 on topic Whir at 1000rpm
Not modified completely standard.
This is at a standstill.
I wouldn't drive down the road without a working waterpump!
- reaper
- Visitor
07 Jan 2013 20:24 #57424
by reaper
Dipped the clutch ? Could be the release bearing
- jbs215
- Visitor
07 Jan 2013 20:26 #57426
by jbs215
Tried that, there is a slight noise from the thrust bearing but not the main noise.
- reaper
- Visitor
07 Jan 2013 20:32 #57428
by reaper
Hmm
Not many more moving parts to go at , have you tried a mechanics Stethoscope to try and pin point the source of the noise
Time to create page: 0.134 seconds
