Radio, clock and cig. lighter not working
- Raithrover
30 Dec 2012 18:12 #56613
by Raithrover
Radio, clock and cig. lighter not working was created by Raithrover
Radio, clock and gig. lighter stopped working after plugging in accessory . Through the 'net tracked the problem to a fuse in the box under the dash. Replaced it and now the radio and clock work. Cig. lighter does not !
What to do about the cig. lighter as I need it for phone etc ? Is there another fuse somewhere or what ?
Jimny 2007
Jimny 2007
- reaper
30 Dec 2012 19:10 #56620
by reaper
Replied by reaper on topic Radio, clock and cig. lighter not working
What exactly did you plug in to make it blow ? Im guessing something with a high amp draw . If you have replaced the fuse and the cig lighter still doesnt work it time to take it out and check the wires
- little jimny
30 Dec 2012 20:54 #56625
by little jimny
Replied by little jimny on topic Radio, clock and cig. lighter not working
Agreed. The trim around the centre console comes out quite easily. Pop out the ashtray and there are two screws there at the top, a further two under the bottom of the trim and a single screw at the also bang in the centre at the top. It then just unclips, taking the lighter socket with it. Power to the lighter is in the centre and the earth terminal is on the side. If you've got 12V across them (with the ignition on) but the lighter socket still doesn't work then it's time to get another one.reaper wrote: ...If you have replaced the fuse and the cig lighter still doesnt work it time to take it out and check the wires
- JerseyJimny
30 Dec 2012 22:03 #56633
by JerseyJimny
Replied by JerseyJimny on topic Radio, clock and cig. lighter not working
Would be helpfull to know how it got broken... If it was a power surge it could of fried the wiring
Try a few acessories with a ciger lighter socket... It might be the actual charger that is broken?
- Raithrover
30 Dec 2012 23:29 - 30 Dec 2012 23:32 #56643
by Raithrover
Replied by Raithrover on topic Radio, clock and cig. lighter not working
Got a little ceramic heater for Christmas ! Problem occurred when I plugged it in !
Had the fascia off some weeks back to put in a unit to use Usb drives through the radio.
Excuse my ignorance but what kind of 'tool' do I need to check the power?
Last edit: 30 Dec 2012 23:32 by Raithrover. Reason: additions
30 Dec 2012 23:40 #56644
by kirkynut
Replied by kirkynut on topic Radio, clock and cig. lighter not working
Just a test lamp will do. I have a purpose made test lamp I bought with a crocodile clip on a bit of wire and the lamp it's self has a pointy probe.
I bulb with two bits of wire would suffice. Grab a headlamp bulb and crimp some female spade connections to bits of wire to slide in it and touch the wire to the feeds to the cigarette lighter to see if it's got power to it. If so the cigarette lighter it's self is at fault and if not it's a power supply problem somewhere along the line.
Time to create page: 0.209 seconds
