No Fwd when in 4wd
- Dan_w
- Visitor
27 Dec 2012 19:15 #56355
by Dan_w
No Fwd when in 4wd was created by Dan_w
Hi guys, you may have seen that I took the Jimny to Silndon on Sunday to a play and play day and lost drive to the front wheels, today I did some investigation but I am now after some advice. I will list below what I Have checked and the outcome, if anyone can point me in the direction of what to check next or what the issue could be it would be a great help.
Engaging 4wd both hubs engage, they can be felt and heard clicking when activated.
Pipe work has also been removed at the hubs and using a vacuum gauge have confirmed that there is vacuum on each pipe when engaging /disengaging.
4wd selected and all 4wheels jacked off the ground drive can be seen going to both rear wheels and front prop spinning ... Nothing at front wheels.
Auto hubs removed and confirmed everything is free to move.
Turning the half shaft of either wheel does not turn the other end in the opposite direction, turning of both forwards does not turn the prop.
Removing the curclip on the end of the hard shaft shows about 5-10 mm play on both sides.
And that is as far as I got today, I was not sure how to fully remove the half shafts to investigate further. Does it sound like something is damaged in the front diff or one of half shafts has snapped?
- Dan_w
- Visitor
27 Dec 2012 19:18 #56356
by Dan_w
Replied by Dan_w on topic No Fwd when in 4wd
Oh and I just remembered I forgot to add that I seem to have lost about half a turn on full lock in both directions when moving slowly.
Thanks guys
Thanks guys
- JimnyDan
- Visitor
27 Dec 2012 20:27 #56367
by JimnyDan
Replied by JimnyDan on topic No Fwd when in 4wd
Hope you get it sorted mate , all the best
- adamjimny
- Visitor
27 Dec 2012 22:17 #56374
by adamjimny
Replied by adamjimny on topic Re: No Fwd when in 4wd
Cv joint by sounds of it
sent from my Samsung Galaxy S2 using tapatalk
- Dan_w
- Visitor
27 Dec 2012 22:55 #56378
by Dan_w
Replied by Dan_w on topic Re: No Fwd when in 4wd
Thanks Adam
Have just had a search through the forum and it sounds about right, the how to guide for changing doesnt sound too bad so hopefully I can give this a go and be back on the road for the weekend providing I can get a replacement cv joint.
- Dave n lincs
- Visitor
27 Dec 2012 23:13 #56379
by Dave n lincs
Replied by Dave n lincs on topic Re: No Fwd when in 4wd
Yea sounds like the cv joint I had this problem on my old girl. It's not a bad job to do really.
Time to create page: 0.198 seconds
