M16A with 235/75/15
  • minare
25 Dec 2012 17:38 #56183 by minare
M16A with 235/75/15 was created by minare
Hey all,
I have Jimny 09 1.3 vvt Automatic with electronic transmission
lifted with trail master 2.5-3 inch
i run stock tyres size 205/70/15 maxxis M8060
and air locked rear
when swap engines into M16A vvt should be enough power to drive easy with 235/75/15 tyres
my question is if it is right to do this, if al the unite (auto gear, transmission...) will survive under this new bigger load.
what other effects a engine braking
hope to get answers :)
thanks all
Guy
  • adamjimny
25 Dec 2012 18:14 #56184 by adamjimny
Replied by adamjimny on topic M16A with 235/75/15
it will have the power to drive but virtually no engine breaking without a lower ratio transfer box
  • minare
26 Dec 2012 06:38 #56231 by minare
Replied by minare on topic M16A with 235/75/15
what about the other Tbox and the transmission, will survive under this load?
it also can help me how to lower the ratio, i guess that if the transfer not strong enough, the best option is to change ring and pinions (if i dont tink of swap to samurai tbox)
thanks
  • Bigchridy
26 Dec 2012 10:42 #56240 by Bigchridy
Replied by Bigchridy on topic Re: M16A with 235/75/15
M16a with a manual transmission and standard transfer box works fine with 235 tyres. Acceleration is better but top speed is the same due to gearing. Engine braking is the same as with the m13a.
Not too sure how it will be effected with the auto box.
Hope this helps.
Chris
Sent from my Nexus 7 using Tapatalk 2
  • ilten
27 Dec 2012 19:18 - 04 Jun 2013 13:11 #56357 by ilten
Replied by ilten on topic M16A with 235/75/15
Well, ring and pinions are hard to come by and rather expensive. I have a '07 with manual transmission and I'm running 30 x 9.5 BFG MT KM2. I recently installed a 20% kit from a Low Ratio Gearset provider in my transfer box and I couldn't be happier (ok, I could with a 1.6 engine - but you know what I mean...).
Installation is a breeze, and my gearing is back where it was with stock tires. Only downside is it's expensive, but still cheaper than most other options. And they do make a kit for the Jimny with automatic transmission......
ilten
Last edit: 04 Jun 2013 13:11 by mlines.
  • minare
30 Dec 2012 12:12 #56583 by minare
Thank you ilten,
for how much time you already use this gear set?
i heard that with this kit there is too much load on the transfer chain and it become to slip
but you know.. for me its a rumor... you are the first source for this case now.. :) doesnt is too much (20% lower) at high?
thanks
Guy
Time to create page: 0.307 seconds
