Dumb radiator question
  • ronm
23 Dec 2012 16:20 #56056 by ronm
Dumb radiator question was created by ronm
2001 soft top jimny
Had my jimny for ten years and fluid levels always been spot on,however with this recent seriously cold weather thought maybe time to refresh the antifreeze.
Drained the system and refilled with plain water twice to flush out the crap until all was running clean. emptyed again and refilled with proper mixture in accordance with workshop manual directions.
Test drive a couple miles to circulate,heater fine, temp gauge fine, no leaks and allowed to cool, Checked to see if ok, however water level rose in overflow tank and radiator was down by same amount assumed trapped air working round system so empted overflow to correct level and topped up rad. left a few days checked levels fine and went for another short trip and same happened again.
Am I doing something stupid here, do jimnys have any hidden airlocks. Aways do with heater open
Have done many cars over the years without hassle and a couple of renaults in the past have have had bleed valves in the heater hoses.
Would like to sort before Xmas driveround at Bordon
24 Dec 2012 06:01 #56088 by kirkynut
Replied by kirkynut on topic Dumb radiator question
It's normal for the level in the expansion tank to rise by 1/2 - 3/4 of an inch when the coolant gets hot from normal use. There is a spring in the rad cap to allow it and it siphons back as it cools.
  • ronm
24 Dec 2012 16:09 #56119 by ronm
Replied by ronm on topic Dumb radiator question
Thanks Kirkynut,yeah I understand what you saybut the fluid level is rising by about 11/2 inches and not flowing back on cooling.
Will top up rad again and syphon expansion tank to proper level and see what happens.
System was fine before levels never moved, only items disturbed were drain tap and radcap (which does not appear damaged)
Perhaps radcap not seating properly allowing expansion but sucking in air on cooling instead of dawing fluid back
ronm
  • suzuki jimny fella
24 Dec 2012 17:24 #56126 by suzuki jimny fella
Replied by suzuki jimny fella on topic Dumb radiator question
what coolant you use mate
  • ronm
24 Dec 2012 17:41 #56129 by ronm
water anti freeze(blue) 50/50
  • safarimny
10 Jan 2013 13:22 #57693 by safarimny
Replied by safarimny on topic Dumb radiator question
Hi ronm and everyone.
Were you able to narrow this down and fix it? I have the same problem after a flush. Have bled out any air, smelt the coolant- it smells free of exhaust gas and the rad cap looks intact.
Can't see what else could be causing this problem.
Does anyone have any ideas?
Thanks.
Time to create page: 0.098 seconds
