leaking rear driveshaft seal
- LiamAshurst
19 Dec 2012 19:57 #55804
by LiamAshurst
leaking rear driveshaft seal was created by LiamAshurst
Hi.
After moving the car off the drive this morning a puddle of oil was noticed, after putting the car up on a garage ramp it appears to be the seals on the back left driveshaft. Anybody have any ideas of the best place to source the parts from and how easy or hard the job will be.
Thanks for any help.
Liam
Liam
19 Dec 2012 20:01 #55806
Replied by mlines on topic leaking rear driveshaft seal
Do you mean the axle oil seal inside the axle?
If so your bearing is most likely shot.
Bearing kit is here www.bigjimny.com/store/index.php/service...it-non-abs-/p_5.html
If you are confident that it is just the oil seal then that is here www.bigjimny.com/store/index.php/service...le-oil-seal/p_9.html
But I would suggest that something has caused the seal to fail, such as the bearing or a bent driveshaft
The following user(s) said Thank You: LiamAshurst
19 Dec 2012 20:02 #55807
oh - and the "how to guides" on this website show you how to do it
- LiamAshurst
19 Dec 2012 20:12 #55808
by LiamAshurst
Replied by LiamAshurst on topic leaking rear driveshaft seal
that sounds more like it. I'd been told that it would most likely be caused by a worn bearing.
Thanks
Liam
Thanks
Liam
