1998 JB33W G13B JIMNY IDLER PULLEY BEARING REPLACE
- KHUNDAN
11 Dec 2012 08:20 - 11 Dec 2012 08:22 #55327
by KHUNDAN
1998 JB33W G13B JIMNY IDLER PULLEY BEARING REPLACE was created by KHUNDAN
My idler pulley is whinning sometimes. If I spray it with WD-40 it's ok for a few days then it starts again. Was told the idler pulley assembly was very expensive but that the bearing good be replaced.
I need the part number for the bearing so that I can get the bearing andf then replace it. I have no manual and have searched forever trying to get a parts manual with no luck..
Anyone have the part number so I can get the correct bearing?
Yes I could pull the pulley off and disassemble it and get the bearing number but its my only vehicle thus the need to buy the bearing and take it home and then dissassemble it.
Thanks
Dan
Thanks
Dan
Last edit: 11 Dec 2012 08:22 by KHUNDAN. Reason: Idler was spelled wrong...
- vitara_mad
11 Dec 2012 09:17 #55329
by vitara_mad
Replied by vitara_mad on topic 1998 JB33W G13B JIMNY IDLER PULLEY BEARING REPLACE
tbh it takes 5 mins to take the pully off so easy enough to take it off & check number / measure bearing & put it back on until u get new 1
i have a spare somewhere if i find it i will check number / measure it
- Drew
11 Dec 2012 11:13 #55337
by Drew
Replied by Drew on topic 1998 JB33W G13B JIMNY IDLER PULLEY BEARING REPLACE
Hi
Its a 6003 2RS (17 x 35 x
Just go on simply bearings.co.uk or go to any bearing supplier.
Should cost no more than £3 for a good brand SKF, NTN etc.
Car suppliers always charge a fortune for bearings but people don't realise that they are so readily avaliable and cheap from the right place. You could even get one from fleebay if you search the bearing number.
Time to create page: 0.142 seconds
