Wheel wobble...........!!!
  • jimbob
29 Nov 2012 20:46 #54466 by jimbob
Wheel wobble...........!!! was created by jimbob
Hi :) My truck starts the death wobble around the 30 to 45 mph and only down hill when I have hit a pot hole. DOSE NOT DO IT ALL THE TIME :( i have change the kingpin's / wheels balanced /pan hard bushes are ok and shocks tyre size 195/80/15 on steel rims with 32mm spacers and no lift kit and no steering damper, this is what I have come up with when the wheels are turned there is a lot of movement side to side but not when straight, so i have put it down to the steering box is warn. Have some one grip the steering wheel so it does not move in a straight line and try to move the wheels side to side i have a slight movement there now just turn the steering wheel a turn and grip the steering wheel then try move the wheel side to side ( I have a lot of movement from my wheels side to side when I have turned the steering ) so there for i think the steering box is warn i have turned the screw in top of the steering box and its still the same and this is all done with the truck on a ramp. I am changing the steering box next week so i will let you know what the out come is.
  • darthloachie
29 Nov 2012 22:50 #54481 by darthloachie
Replied by darthloachie on topic Wheel wobble...........!!!
check the track rod ends as they wear and cause intermittent wobble
  • dirtydogz
29 Nov 2012 23:13 #54483 by dirtydogz
Replied by dirtydogz on topic Wheel wobble...........!!!
Don't forget you have 4 track rod ends on the jimny two on the drag rod + two on the tie rod.
  • phippj1
30 Nov 2012 11:14 #54494 by phippj1
Replied by phippj1 on topic Wheel wobble...........!!!
Let us know you you get on jimbob as I have exactly the same issue and have a fair bit of play from the power steering box.
  • jimbob
02 Dec 2012 20:51 #54696 by jimbob
Replied by jimbob on topic Wheel wobble...........!!!
Well boy's and girl's I have been working on the truck this weekend and I have found that the rear radius arm bushes to the axle are shot to bits, the panhard rod bushes front and back are soft ish I have not fit the other steering box I have just adjusted the screw on top of the steering box and found that it has made a big difference to the drive and I get a real good feed back through the steering wheel.The next thing to do now is drive it for a week or two to see if it really has made a big difference or not. This is what i did be for I adjusted the screw I put tip x just on one side of the screw slit on top so I could see how much it had tightened or moved,well I had the front wheels in a straight line engine off with a 17 mm socket on long bar i cracked it of just a bit the put some WD40 on to soak. After that I got a 17 mm spanner held the nut and turned the screw in a quarter at a time then locked it off and had a drive. After doing this for about three to four times I got it spot on but after driving a few miles in a straight line it just felt that bit too tight so I have backed it off just a tad and found the truck to be 95% better I do still get a small amount of wheel shimmy/wobble but that's from hitting pot holes. What I think after doing all this and reading what other's say about wheel wobble/shimmy is due to the size of wheel and 4x4 Your wheels must shimmy left to right like mad so thats going to put strain on the gears in the steering box and there for causes the steering box over time to become slack/loose. Am not saying this is the solver of all wheel wobble/shimmy but is has taken a lot of the slack out of my steering. Al re post over the next week on how the truck drives :)
02 Dec 2012 21:15 #54700 by mlines
Replied by mlines on topic Wheel wobble...........!!!
jimbob wrote: rear radius arm bushes to the axle are shot to bits
This is where I would concentrate my efforts next!
Time to create page: 0.106 seconds
