Boot jack
  • dirtydogz
29 Nov 2012 20:12 #54461 by dirtydogz
Replied by dirtydogz on topic Boot jack
2 TON will be ok to lift the jimny.
29 Nov 2012 20:17 #54462 by facade
Replied by facade on topic Boot jack
You may find that that jack does not have enough lift to raise the wheel off the floor high enough to get an inflated tyre on, starting with a flat tyre.
I have the jack out of a Rangerover/Discovery, 2000kg lift, two sections, and a shaped saddle to go around the axle tube. Cost £10 from a Landrover breaker.
Bit big for the tool tray, would need strapping in somehow.
The following user(s) said Thank You: jimnyonhigh
  • reaper
29 Nov 2012 20:36 #54464 by reaper
Replied by reaper on topic Boot jack
If you jack from the hockey stick you wont need much movement to get the wheel up in the air , i swaped the stock tyres to 32's with the factory scissor jack :-)
  • jimnyonhigh
29 Nov 2012 20:55 #54469 by jimnyonhigh
Replied by jimnyonhigh on topic Boot jack
Cool brilliant, im running on 235/75R15 Kingpin Amazons.
Cheers for the help and tips guys.
  • Skinhead
29 Nov 2012 22:04 #54474 by Skinhead
Replied by Skinhead on topic Boot jack
jimnyonhigh wrote: Thanks for the reply Reaper, would a HEAVY DUTY 2 TON HYDRAULIC BOTTLE JACK LIFT be ok or should i get a higher ton, like 5 ?
Just want something simple incase of a puncture.
Attachment not found
I bought 1 of these, didnt use it, threw it in the shed. Simply because that saddle thingy is about the size of a 20p! If it had a bigger 1 it would be ok for a wheel change, just have to put it straight under the radius arm.
  • dirtydogz
29 Nov 2012 22:45 - 29 Nov 2012 22:46 #54480 by dirtydogz
Jimnyonhigh get one from screwfix it come with plastic carry case. www.screwfix.com/p/2-tonne-bottle-jack/54957
Last edit: 29 Nov 2012 22:46 by dirtydogz.
Time to create page: 0.390 seconds
