Rear Rough Country shocks - top bush and collar
  • GuardianAngel
11 Nov 2012 23:08 #52978 by GuardianAngel
Replied by GuardianAngel on topic Rear Rough Country shocks - top bush and collar
dirtydogz wrote: I think you might need to fit some rear shock brackets, your right the R.C shocks are a lot fatter than the standard shock.
Thanks for the info. OK, stupid question coming up... :unsure:
...how do the brackets help with the fact the shocks are fatter?
11 Nov 2012 23:21 #52984 by dirtydogz
It will lift the shock up higher and away from the axle, if you don't fit them it will hit the spring cup on top of the axle.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
The following user(s) said Thank You: GuardianAngel
  • GuardianAngel
11 Nov 2012 23:28 #52986 by GuardianAngel
dirtydogz wrote: It will lift the shock up higher and away from the axle, if you don't fit them it will hit the spring cup on top of the axle.
I see what you mean, thanks. Looks like this "straight swap" of shocks is fast becoming not very straight!
  • GuardianAngel
12 Nov 2012 12:33 #53013 by GuardianAngel
OK, so JimnyBits have come back to me after trying a standard RC shock on a standard Jimny. He has confirmed that the bushes are very tight, and that the size of the shock leaves almost no room for any movement (unless I was to use the brackets as suggested earlier in this thread). As a result he is not recommending the RC shocks as I just want a straight swap out.
They have very kindly offered me a full set (front and back) of TrailMaster shocks at cost price instead, so I will fit these and let you know the outcome.
I will say that the customer service from JB has been excellent :)
  • GuardianAngel
18 Nov 2012 21:17 #53624 by GuardianAngel
Have fitted rear TM shocks (standard length). They are fatter than the standard factory shocks but I have driven about 50 miles and there is no signs of rubbing or fouling. The car does feel different but that probably expected as the old ones were knackered! Now need to find time to fit the fronts.
Some photos, not the best angles, will take some better ones if anybody wants them.
  • markyp2000
18 Nov 2012 21:41 #53626 by markyp2000
Replied by markyp2000 on topic Rear Rough Country shocks - top bush and collar
nice looking shocks but i have to say your boot floor looks quite rusty as do other bits on it do you live near the coast or driven it in the sea
[/quote]
Time to create page: 0.315 seconds
