What do I need to change for a 2" body lift + 3"
- Loaf
09 Nov 2012 03:33 - 09 Nov 2012 03:44 #52692
by Loaf
What do I need to change for a 2" body lift + 3" was created by Loaf
Hi, i'm currently in the market for a Jimny for off-road purposes and I am planning on lifting the body
2" and the suspension 3".
Afaik i'll have to get a steering shaft spacer and longer brake lines. What else do I need?
Last edit: 09 Nov 2012 03:44 by Loaf.
- bigoffroader
09 Nov 2012 09:27 #52701
by bigoffroader
Replied by bigoffroader on topic What do I need to change for a 2" body lift + 3"
You actually only need the lift kit and steering spacer. Longer brake lines are really only needed if you are doing a spring lift and body lift. They are advisable if going serious offroading but not essential.
I had standard lines on for quite some time with a 2" body lift and a 2" spring lift but as I now have a 4" spring lift I needed longer lines.
- vitara_mad
09 Nov 2012 11:52 #52702
by vitara_mad
Replied by vitara_mad on topic What do I need to change for a 2" body lift + 3"
i did not have a steering spacer with 3" susp & 2" body lift so they are not always needed
- Loaf
10 Nov 2012 18:12 - 10 Nov 2012 20:47 #52810
by Loaf
I'm planning on a 2" body lift and 3" spring lift.
Would I need the caster adjusting bushings?
Replied by Loaf on topic What do I need to change for a 2" body lift + 3"
bigoffroader wrote: You actually only need the lift kit and steering spacer. Longer brake lines are really only needed if you are doing a spring lift and body lift. They are advisable if going serious offroading but not essential.
Last edit: 10 Nov 2012 20:47 by Loaf.
- bigoffroader
10 Nov 2012 21:17 #52836
by bigoffroader
yes you would
Time to create page: 0.186 seconds
