Stir Fry 'Shifter...
04 Nov 2012 19:50 #52284
Replied by mlines on topic Stir Fry 'Shifter...
Bolt 9 in the above picture is quite important as well
The remote mechanism forms part of the rear gearbox mounts (not in picture) these can break as well.
The following user(s) said Thank You: Beano
- Beano
05 Nov 2012 20:47 #52406
by Beano
Replied by Beano on topic Stir Fry 'Shifter...
Just an update folks...
Thought it may be useful for anyone else who may be having the same problem if i give you the final result of this...
Basically, underneath the Jim, in the transmission tunnel where the shifter comes through from the cab, ALL of the bolts that connect the shifter linkage to the gearbox were loose.
I mean COMPLETELY loose. To the point where one had even already fallen out!!
All tightened up and missing one replaced, problem solved!
Just thought that may be useful for others to know before you go ripping apart anything!
Thanks all for the advice / pictures..
Bean
Bean
- Tadpole
06 Nov 2012 09:57 #52447
by Tadpole
Replied by Tadpole on topic Stir Fry 'Shifter...
Pleased is was that easy for you, thanks for the update ..
