wheels skiding when in 4wd
  • supergaz
03 Nov 2012 17:48 #52103 by supergaz
Replied by supergaz on topic wheels skiding when in 4wd
Both different engine models. Worth jacking up the whole car so all wheels are clear then checking the front turn the same speed as the rear. My bet is it is the wrong ratio diff, I know autos are different to manuals.
  • markyp2000
03 Nov 2012 17:59 - 03 Nov 2012 18:00 #52110 by markyp2000
Replied by markyp2000 on topic wheels skiding when in 4wd
supergaz wrote: Both different engine models. Worth jacking up the whole car so all wheels are clear then checking the front turn the same speed as the rear. My bet is it is the wrong ratio diff, I know autos are different to manuals.
if you do that then the opposite wheel will turn the other way if you do it as i said then that would be better
Last edit: 03 Nov 2012 18:00 by markyp2000.
  • chris123
03 Nov 2012 18:07 #52114 by chris123
Replied by chris123 on topic wheels skiding when in 4wd
yeah that would explain the symtoms, will try that. thanks all for the help
  • Paul4x4
03 Nov 2012 18:10 #52115 by Paul4x4
Replied by Paul4x4 on topic wheels skiding when in 4wd
Or just simply mark the tires, put it into 4wd, drive forward(preferably on gravel) some and check out if the marks are in the same place.
03 Nov 2012 19:31 #52129 by mlines
Replied by mlines on topic wheels skiding when in 4wd
  • markyp2000
03 Nov 2012 19:53 #52131 by markyp2000
Paul4x4 wrote: Or just simply mark the tires, put it into 4wd, drive forward(preferably on gravel) some and check out if the marks are in the same place.
seeing at the tyres are the same size thay will end up in the same place unless it skids then that defeets the object of doing it
just follow what i posted if you under stand it and if its wrong it will show
