4wd light flashing on dash
11 Nov 2012 22:24 #52962 by facade
Replied by facade on topic 4wd light flashing on dash
join the 2 wires that go to the vacuum switch together, don't forget to plug the vacuum tapping on the inlet manifold.
Or just plug the rubber pipes that go down to the axle.
The following user(s) said Thank You: Smoggy
  • Smoggy
11 Nov 2012 22:30 #52964 by Smoggy
Replied by Smoggy on topic 4wd light flashing on dash
Thanks Facade,
I have already removed every link of vacuum pipe from the car (got SJ axles on my car) and have already plugged up vacuum pipe hole on inlet manifold. Will join wires on switch as you suggest
Time to create page: 0.136 seconds
