Water pump or not???
- myers647
30 Oct 2012 19:32 #51685
by myers647
Water pump or not??? was created by myers647
Hi my jimny is boiling over I can hear it bubbling when I stop & its leaking water from what I think is the water Pump under where all the belts are.can the pumps be fixed or do you just replace and is it an easy job.
The temp guage is normal.
Thanks
James
Thanks
James
- Blakey
30 Oct 2012 21:15 #51710
by Blakey
Replied by Blakey on topic Water pump or not???
Did the water pump and belt on mine and only took about hour or so. Don't think they can be repaired but are not that much to buy.
- myers647
30 Oct 2012 21:19 #51711
by myers647
Replied by myers647 on topic Water pump or not???
Ok thanks mate what symptoms did u have and have u got any tips how u did it.
Thanks
James
Thanks
James
- Blakey
30 Oct 2012 22:50 #51731
by Blakey
Just changed mine as was doing the cam belt anyway. You can get the full step by step guide from the workshop manual. When your in there would do the belt at the same time. Its pretty straight forward just take your time and toque it all up and make sure timings is right.
- deedar
31 Oct 2012 23:02 #51820
by deedar
Replied by deedar on topic Water pump or not???
hi mine was doing the same it was the water pump it only cost me £23 and about a hour to change but you have got to take them cam belt tension er off so make sure that the cam shaft is lined up with the mark on the block and you want to put it to the E as there are to marks and the same on the crankshaft put them two marks so that they are matching and jobs a good en
