Sticking Alternator Pulley or not!
  • Smoggy
29 Oct 2012 18:23 #51591 by Smoggy
Sticking Alternator Pulley or not! was created by Smoggy
After noticing that the alternator pulley was not turning and fearing another fanbelt snap, I tried to ease it off by spraying it with WD40 and turning it with a pair of grips. It remained very tight and when the engine was running it was screeching, after all this effort I suspected worn bearings (the fanbelt was not over tight and had been set with correct amount of flex).
Now I have removed the alternator and expected it to be tight to turn, no it was free as a bird with no sign of binding!
Now I am confused :(
Has anyone else experienced anything similar?
ps the car has done 110k miles but not sure if alternator is original.
  • markyp2000
29 Oct 2012 18:30 #51594 by markyp2000
Replied by markyp2000 on topic Sticking Alternator Pulley or not!
whats the bottom pully like has it come apart ie middle and outer bit
  • Smoggy
29 Oct 2012 19:11 #51601 by Smoggy
Replied by Smoggy on topic Sticking Alternator Pulley or not!
Sorry Mark what do you mean when you say the 'bottom pulley' excuse my stupidity.
  • markyp2000
29 Oct 2012 19:27 - 29 Oct 2012 19:29 #51605 by markyp2000
crank shaft pully thats at the bottom its a term used in the motor trade
Last edit: 29 Oct 2012 19:29 by markyp2000.
  • Smoggy
29 Oct 2012 21:11 #51625 by Smoggy
No ive been out and checked it, it all seems to be in one piece.
  • markyp2000
29 Oct 2012 21:35 #51631 by markyp2000
does it only do it with the alternator belt on what about the P A S belt tensioner and doest it do it when the P A S belt is fitted
