Brake flares onto ORA flexis
- Smoggy
24 Oct 2012 18:07 - 24 Oct 2012 18:25 #51176
by Smoggy
Brake flares onto ORA flexis was created by Smoggy
I have repiped all my brake lines in copper but my connnections to my ORA front flexis are weeping under pressure. Does anyone know if the pipe should have a single or double flare?
Last edit: 24 Oct 2012 18:25 by Smoggy.
- bigoffroader
24 Oct 2012 18:11 #51177
by bigoffroader
Replied by bigoffroader on topic Brake flares
female's should have single and
male should have double
- Smoggy
24 Oct 2012 18:23 #51182
by Smoggy
Replied by Smoggy on topic Brake flares onto ORA flexis
Tony, I thought all the hard pipefittings are males are they not?
I remember when I removed the male fittings that go to the rear wheel cylinders that the old steel pipe just had a single flare and they were a male fitting/plug. None of these are leaking.
The thing was I fitted the ORA flexis at the same time as making the new pipe ends so had nothing to compare the ends with.
Rob from ORA might know maybe.
- markyp2000
24 Oct 2012 19:31 #51189
by markyp2000
Replied by markyp2000 on topic Brake flares onto ORA flexis
look in the end of the ora pipe see if it is dished in or domed out and make flare to suit
- Smoggy
24 Oct 2012 20:42 #51196
by Smoggy
Yeah cheers Marky never thought about that..... doh.
It's domed so single flare it is.
- markyp2000
24 Oct 2012 21:09 #51201
by markyp2000
Time to create page: 0.178 seconds
