Diff plug tool
  • Calg
20 Oct 2012 22:17 #50937 by Calg
Diff plug tool was created by Calg
Hi
I need to top up my front diff after a kingpin bearing replacement and don't want to use a 3/4 ratchet in the plug as its slightly loose- if it can be rounded or stripped I'm the man to do it
Searched on eBay and online and can't find a thing ?
What does everyone else use ?
Thanks
  • ZookFastback
21 Oct 2012 01:01 #50938 by ZookFastback
Replied by ZookFastback on topic Diff plug tool
If your ratchet is ratshit, what about your extension bars?
  • MWells
21 Oct 2012 06:56 #50940 by MWells
Replied by MWells on topic Diff plug tool
I use one of these and it is a very good fit.
21 Oct 2012 07:09 #50941 by facade
Replied by facade on topic Diff plug tool
As MWells post, the plug needs a 10mm square, a 3/8" ratchet is a loose fit (9.5mm).
You can buy sets of drain plug tools, but if someone has previously attacked it with a 3/8 ratchet, you will find that the 10mm doesn't work either.
The best solution is the correct tool, and a set of replacement plugs.
Some of us chisel them out carefully, and then weld a hexagon bar onto the plug.
  • Calg
21 Oct 2012 09:00 #50943 by Calg
Replied by Calg on topic Diff plug tool
Thing I will order that 10mm square socket - thanks for the link.
I got a fair few tools and tried a few no joy. Not got a welder either unfortunately.
A friend had a fourtrak and the diff plugs on that are crap as well. Must be a Japanese thing.
Thanks
22 Oct 2012 08:02 - 22 Oct 2012 08:22 #51019 by kirkynut
Replied by kirkynut on topic Diff plug tool
I ought to buy a proper socket but what I have been doing is putting my biggest set of mole grips round the outside to undo it and using a ratchet to do it back up - as it doesn't need as much umph to do up.
Edit: Just bought one from the link above £14.07 though with postage!!! Did it anyway as I've not been able to find one in ages and if I don't buy now I never will and will have to keep buying new diff plugs! So prob cheaper in the long run!
Last edit: 22 Oct 2012 08:22 by kirkynut. Reason: update
Time to create page: 0.169 seconds
