Viscous Fan
15 Mar 2009 19:56 #472 by mlines
Viscous Fan was created by mlines
At what temperature should a viscous fan (Jimny 1.3 JLX) stiffen up?
With the temperature gauge at "Normal" I can spin the fan by hand. My Jimny overheats if you give it real work to do,
17 Mar 2009 11:55 #475 by kirkynut
Replied by kirkynut on topic Re:Viscous Fan
I don't think my Jimny Workshop Manual CD has that kind of information on it so I can't help.
I'm guessing that you've checked your radiator is clear of mud etc given your experience.
I think the best person to ask would be Darren at KAP and see if he has a god 2nd hand one he can send you to replace yours.
Our old 410's fan was a straight bolt on jobbie with no viscous clutch to worry about, you could araldite the clutch mechanism up to lock it so it works at full efficiency all the time! I know it will draw more from the engine and you've already said your toping out at 60 mph in your latest article, but it's better than a blown head gasket and warped head / block.
Or, maybe now could be the time for an electric fan eh?
25 Mar 2009 13:17 #499 by kirkynut
Here could be a cheap solution for you Martin
cgi.ebay.co.uk/2000-SUZUKI-JIMNY-1-3-VIS...sidZp1742.m153.l1262
25 Mar 2009 14:11 #502 by mlines
Replied by mlines on topic Re:Viscous Fan
Hey, thats cool how you embedded the widget!
I am probably going to go for the jam it permanently on solution as it is cheap. I am going to see what happens after Hogmoor.
25 Mar 2009 17:07 #506 by kirkynut
I have no idea how I did the widget thingy, I just copied and pasted it. The fixed up way should keep it cooler.
Time to create page: 0.159 seconds
