replacing exhaust
- nate78
- Visitor
17 Oct 2012 14:25 #50560
by nate78
replacing exhaust was created by nate78
well, my MOT is due next week so thought it best to replace the exhaust as it is very badly rusted and i have had a brand new exhaust in my garage,
started withe the joint at the manifold, the bolts didnt budge, applied wd40, still nothing, tried heat but, still nothing, next in my arsonal of tools the good ole grinder, i had to cut the exhaust into pieces then take the manifold off so i can now attempt to remove the 2 bolts on my work bench, so that will be my job when i finish work, yay!!
17 Oct 2012 14:36 #50561
by facade
Replied by facade on topic replacing exhaust
The piece that bolts to the manifold contains the catalyst, they are expensive. Good job you have a new one.
I generally take the tube cutter to exhausts that are scrap, and then devote the effort to parting the flange/opening the split joint.
- nate78
- Visitor
17 Oct 2012 14:48 #50563
by nate78
Replied by nate78 on topic replacing exhaust
if i had been taking it off for any other reason than to change it i would of spent more time but i just wanted it off, i just hope i dont break a bolt in the manifold when undoing the exhaust bolt
- mudman
- Visitor
17 Oct 2012 15:22 #50568
by mudman
Replied by mudman on topic replacing exhaust
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationiv got to mine for MOT try ebay
the cat is only £65
mid pipe £24
rear box £36
the cat is only £65
mid pipe £24
rear box £36
17 Oct 2012 15:43 #50573
by facade
Thats a good price for a catalyst, the people of Norilsk must work for peanuts :huh:
- nate78
- Visitor
17 Oct 2012 16:52 #50578
by nate78
thats prob the same as the units that i got, they seem ok, will let you know when i fit them
