Odd idling.
- grumpy22
14 Oct 2012 07:16 #50204
by grumpy22
Odd idling. was created by grumpy22
Took the jimbo for its weekly outing yesterday, did about 30 miles. Car started and ran perfectly for first 5 or so then the idle speed at junctions started to creep up from 800 to 1000 and towards my destination around 1800. When I arrived I let the car idle for a while and the speed gradually over about a minute dropped back to 800 alternating between 1400 and 800 on the way down. On the return journey everything was fine and the idle speed normal
Any thoughts? Or is this a sign of something on its last legs? Want it right before winter sets in coz that's what we bought it for
98 13gb 60k hardtop
Thanks
98 13gb 60k hardtop
Thanks
- MWells
14 Oct 2012 09:01 - 14 Oct 2012 09:02 #50210
by MWells
Replied by MWells on topic Odd idling.
Mine did the same, idling fine and then lumpy for a bit then fine again, after a bit of looking around the engine bay i noticed a small split in the vacuum hose coming from the engine to the hub solenoids. A bike puncture repair patch later and all is well.
Mark
Mark
Last edit: 14 Oct 2012 09:02 by MWells.
- Paul4x4
14 Oct 2012 09:23 #50212
by Paul4x4
Replied by Paul4x4 on topic Odd idling.
If the ECU is unable to get temperature reading from the engine, it might cause those symptoms. So the coolant temp sensor might be bad. But can be a vacuum leak too, or something else...
