Moving Fusebox
  • Smoggy
04 Oct 2012 20:31 #49509 by Smoggy
Moving Fusebox was created by Smoggy
Recently I have ground out my old rotted battery tray and welded in a new slightly bigger replacement. This meant that I had to drag my fusebox across towards the engine block slightly. Now with my car being an X-plate and getting on a bit (like me :)) when I moved it, some of the wiring entering the underside of the fusebox was so corroded it seperated from the plugged in spade terminals :(
This has lead me to contemplate moving the box into the car. Now, being an electrician, the concept of altering wiring doesn't phase me (no pun intended) but I would be interested in how people that have done this have found it. Also am I stating the obvious but is it not a big advantage if driving through deep water to have the electrics more protected.
  • ne-crock
04 Oct 2012 21:50 #49516 by ne-crock
Replied by ne-crock on topic Moving Fusebox
if it was already half out i'd move into say the glove box or somewhere similar, i'm using the back of my glove box as a switch pannel, wired my spot lights switch in there going to mount my winch switch in there come christmas,
but then again i've had my bonnet underwwater a couple of times in local fords and had no problems at all, and to be honest smoggy your going to find some preety deep water to get your fuse box underwater, i tell you now i wont be following you into it!
  • Smoggy
04 Oct 2012 21:56 #49518 by Smoggy
Replied by Smoggy on topic Moving Fusebox
:laugh: :laugh: :laugh:
  • markyp2000
05 Oct 2012 17:41 #49555 by markyp2000
Replied by markyp2000 on topic Moving Fusebox
keeping the water out is ok all the time your moving its when it conks out the water comes in i had this in my old sj it was level the the transmison tunnel and wasnt a nice drive home with wet seats
Time to create page: 0.178 seconds
