Ball joint splitter
  • Sponnie
04 Oct 2012 22:04 #49521 by Sponnie
Replied by Sponnie on topic Ball joint splitter
I knocked the kingpin bearing races out using a socket. Its was an impact socket, can't remember the size but I dropped it in then used the socked extensions bar and wacked the race out :)
You may have problems getting the nut off the ball joint, use a wire brush on the thread as this is where the nut can get stuck and start turning the tapered bolt.
  • markyp2000
05 Oct 2012 17:37 #49554 by markyp2000
Replied by markyp2000 on topic Ball joint splitter
if it starts turning put a trolly jack under the track rod end under the joint and jack it up that should stop it turning
Time to create page: 0.186 seconds
