Wheel arch extension ideas
  • niva77
01 Oct 2012 14:14 #49255 by niva77
Wheel arch extension ideas was created by niva77
Picked up a set of 31's on 10" modulars.
I'll have to do some cutting obviously but the tires stick out a mile! What's the legal limit and how do people make their own eyebrows?
  • darthloachie
01 Oct 2012 16:09 #49258 by darthloachie
Replied by darthloachie on topic Wheel arch extension ideas
No eBay APP ID and/or Cert ID defined in Kunena configurationwhen looking down over the tyre nothing should be visible
if you want to do it on the cheap then use conveyor belting
else you could fit defender flexi arches like mine
or you can get wheel arch extensions off ebay
01 Oct 2012 16:36 #49262 by Halford
Replied by Halford on topic Wheel arch extension ideas
think it's OK to see sidewall, but the tread that shouldn't be visible
my ATs with 32mm spacers just passes
  • markyp2000
01 Oct 2012 18:21 - 01 Oct 2012 18:23 #49273 by markyp2000
Replied by markyp2000 on topic Wheel arch extension ideas
tyre/ wheel can not pass the arch at all you could always go the a pvc wimdow/b&q and use a wide plastic trim that thay if on the inside of the windows to tidy it up
Last edit: 01 Oct 2012 18:23 by markyp2000.
01 Oct 2012 18:32 #49275 by Obarno
Replied by Obarno on topic Wheel arch extension ideas
Darthloakie - are they std LR width or wider? Thinking about something like that for my Jimny trialler. Thanks
  • Paul4x4
01 Oct 2012 18:36 #49276 by Paul4x4
Replied by Paul4x4 on topic Wheel arch extension ideas
Halford wrote: think it's OK to see sidewall, but the tread that shouldn't be visible
Correct. :)
Time to create page: 0.365 seconds
