Removed steering damper, now another issue!
  • Jimnyash
30 Sep 2012 11:35 #49135 by Jimnyash
OK, so yesterday, I fitted my steering damper (Discovery 1 with BigJimny bracket as a lot of people on here).
The angle is quite sharp when it's in the back hole of the tie down bracket as I've seen mentioend before.
As it was so close to the pipe running into the radiator, I decided to remove it until I could get a new bracket fabricated to lower it a bit.
I now notice that, after removing the damper, my steering wheel isn't straight when travelling in a straight line!
I've been underneath, and the drag link is still true (although there is a lot more rotational/twisting play in it after cramming up the bracket for the damper) and one of the tie rod ends looks like it's now leaking (great).
Could this cause the issue? I'm certain the steering wheel was spot on before, maybe it was different because the tie rod end didn't move (the drag link will move easily now!!!).
Maybe I need to get the tracking looked at? I just cant figure out how the steering wheel can be off to the left without the tie rod ends moving in or out or the drag link bending.
Any thoughts appreciated.
30 Sep 2012 14:05 #49145 by facade
Jimnyash wrote: I've been underneath, and the drag link is still true (although there is a lot more rotational/twisting play in it after cramming up the bracket for the damper) and one of the tie rod ends looks like it's now leaking (great).
More than likely.
Any play in the joints will show as a movement of the steering wheel.
Possibilities are as you say:
Worn joints
Bent drag link
Bent tie rod
Kingpin collapse
Axle displaced sideways (bent panhard or bracket/ shot panhard bushes)
The following user(s) said Thank You: Jimnyash
  • Jimnyash
30 Sep 2012 15:59 #49166 by Jimnyash
Replied by Jimnyash on topic Removed steering damper, now another issue!
Thanks Facade.
Think I'll get the end sorted. Now there's grease coming out, it isn't going to get better and there's space for other stuff to get in (mud, water, grit).
Get that sorted, then new bracket, then damper back on.
Typical. Try to fix one issue and create another!
  • Jimnyash
07 Oct 2012 17:45 #49680 by Jimnyash
Replaced the tie rod ends. Makes a lot of difference!
  • Tadpole
15 Oct 2012 18:23 #50341 by Tadpole
Replied by Tadpole on topic Removed steering damper, now another issue!
Did you re-fit the steering damper or still waiting for a new bracket?
What difference does the damper make over standard steering?
  • Jimnyash
15 Oct 2012 18:55 #50343 by Jimnyash
Still waiting to sort the bracket.
The short time it was on it did smooth out and add some weight to the steering.
Hopefully I'll get it back on soon.
Time to create page: 0.188 seconds
