Heated wing mirror help?
- VAXXi
25 Sep 2012 06:43 #48706
by VAXXi
Replied by VAXXi on topic Heated wing mirror help?
ECM is the car's main computer.
I don't know about the mirror; some say you take out the exterior shell (painted in the colour of the car) and then push some clips and remove the glass. Bracket should be the same between heated and non-heated versions, don't see why they'd be different.
- phippj1
25 Sep 2012 11:28 #48720
by phippj1
Replied by phippj1 on topic Heated wing mirror help?
Brilliant thank you for your help. What fuse do you reckon should be in the auto relay, i think the diagram says type 4 takes a 15amp, Type 5 takes a 20amp, i presume my jimny is a type 4 being on a 02 plate? Why does the red.wht wire go to the ECM tho?
- VAXXi
25 Sep 2012 12:00 #48723
by VAXXi
Don't see the reason for a fused relay, there's already a fuse in the defogger circuit (in your fuse box).
I don't know why the wire goes to the ECM; perhaps it disconnects the heating after a while, no idea.
03 Jan 2024 20:15 #253236
by Phaeton
Replied by Phaeton on topic Heated wing mirror help?
I know this is a very old post, but has anybody fitted heated mirror glass to a non heated mirror? Gen 3, 2003
19 Mar 2024 10:39 #255169
by jamesdin
Replied by jamesdin on topic Heated wing mirror help?
I had plans to do the same thing this summer, but never got around to it unfortunately. Will follow the thread.
Meanwhile, if it helps, I attach the two diagrams for the mirror cabling ( heated and non-heated versions in high resolution).
There are heated Jimny mirrors on eBay (just the glass and thermal resistance).
Not heated:
Heated:
Hi Can you please post pics again. I understand it is old post, but I hope you have them still.
Time to create page: 0.234 seconds
