rear half shaft seal
- markyp2000
22 Sep 2012 20:50 #48570
by markyp2000
rear half shaft seal was created by markyp2000
i have fitted to rear wheel bearing and 3 seals all on one side and every 6 months or so it keeps leaking i have 2" spacers and the only thing i can think of is that it buts more stress on the bearing but why only on one side has any one ellse come across this
22 Sep 2012 21:02 #48572
Replied by mlines on topic Re: rear half shaft seal
Is it the "long" side or "short" side, as in axle shaft length. I bet its the long side.
If so then I have seen this before with spacers.
Also you may have bent the axle shaft.
Sent from my HP Touch pad using Tapatalk
- markyp2000
23 Sep 2012 19:12 #48628
by markyp2000
Replied by markyp2000 on topic Re: rear half shaft seal
short shaft
23 Sep 2012 20:34 #48641
by facade
Replied by facade on topic rear half shaft seal
Make sure that the outer surface of the bearing retainer ring is as smooth as glass, as this is the surface that the seal runs on. Some of the replacement rings have a rough surface finish.
You may also find that your axle breather is blocked.
- markyp2000
23 Sep 2012 20:40 #48644
by markyp2000
Replied by markyp2000 on topic rear half shaft seal
mmmm didnt think of that ill poke my air line up at lunch tomorrow
Time to create page: 0.303 seconds
