Rust, Hand brakes and rear lights!
  • J-Bro
22 Sep 2012 06:21 #48515 by J-Bro
Rust, Hand brakes and rear lights! was created by J-Bro
Hey
My dream car (strangely) has always been a Jimny (in black) amazingly my dreams came true a couple of days ago! So far so good. I love it! But there are few things unsure about.
Rust: Lots of rust in the boot from under rear seats to the rear door. I had the best look I could before I bought it! But I guess you don't see everything until you get it home. Only some spots are weak. Has anyone just welding plates over the rusted area?
Handbrake: The handbrake light is always on. Sometimes goes off but useally on. I've checked all brake fluid levels and brake lights. Could it just be as simple as the hand brake sensor? And are they easy to get too?
Rear lights: above the reverse light is there suppose to be any lights? Ie brake/side lights. Or at night do I just relie on the bumper ones and the strip?
Any help would be great!!!
Suzuki Jimny - 2000 JLX
  • Gromit
22 Sep 2012 08:30 #48520 by Gromit
Replied by Gromit on topic Rust, Hand brakes and rear lights!
Must people just weld plates over bad areas.
Sounds like a faulty sensor, sorry don't know where.
No lights in top ones, just reversing and rear fog . I have fitted some small marker rear sidelights above the upper ones.
  • Nelson83
22 Sep 2012 08:37 #48521 by Nelson83
Replied by Nelson83 on topic Rust, Hand brakes and rear lights!
My black jimny has an iffy handbrake light - always has and always will :-P somebody mentioned ages ago thats its to do with the ignition key - when you've fired it up and it stays on, turn the key back a tiny amount - literally a mill or so, and it goes off :-) works for me and saves an expensive dealer fix
  • J-Bro
22 Sep 2012 08:38 #48522 by J-Bro
Replied by J-Bro on topic Rust, Hand brakes and rear lights!
Thanks for the help!
  • J-Bro
22 Sep 2012 08:39 #48523 by J-Bro
Just had at go at that! Works a treat! Thankyou!
  • Smoggy
22 Sep 2012 11:16 #48536 by Smoggy
Replied by Smoggy on topic Rust, Hand brakes and rear lights!
There is a simple make braker sensor just in front of handbrake below the shroud.
