How to replace rear shocks and what with
- GuardianAngel
19 Sep 2012 11:25 #48356
by GuardianAngel
Cheers!
Sent from my GT-I9100 using Tapatalk 2
Replied by GuardianAngel on topic Re: Re: Re: How to replace rear shocks and what with
GuardianAngel wrote: Be careful with the top bolts not to round them off as the go into captive nuts which corrode so they get seized in. As has been said, plenty of wd40 for days before will help and use a good quality spanner, if possible one that grips on the flats not the corners of the bolt head. Then put copper slip on the bolt when re-assembling to help for next time.
Cheers!
- nicho
19 Sep 2012 18:06 #48380
by nicho
Replied by nicho on topic How to replace rear shocks and what with
hope the steel sleave in the bush has not cold welded its self to the bolt like mine did.its a pain.
19 Sep 2012 18:10 #48381
by j999pre
Grey pick up Jimny
Replied by j999pre on topic How to replace rear shocks and what with
I found it easier access with the rear wheels off. Wd 40 and slacken tighten slacken tighten repeat.
Grey pick up Jimny
The following user(s) said Thank You: GuardianAngel
- myers647
19 Sep 2012 20:52 #48398
by myers647
Replied by myers647 on topic How to replace rear shocks and what with
This is a very good point, its better access with the wheels off but not a necessity.
Time to create page: 0.164 seconds
